Throttle and mixture bellcranks
http://thorp18.com/thorpforum/viewtopic.php?f=35&t=7729
Page 1 of 1
Author:  Ryan Allen [ Wed Mar 11, 2015 7:32 pm ]
Post subject:  Throttle and mixture bellcranks
I am planning to install a throttle quadrant. Does anyone have pictures of their installed throttle/mixture bellcranks and any brackets you made to hold the bellcrank. Just trying to get an idea of the easiest method. No sense in reinventing the wheel.
Author:  Rich Brazell [ Wed Mar 11, 2015 9:26 pm ]
Post subject:  Re: Throttle and mixture bellcranks
Where is the whodeedo going to be put ? Left Side ? Center ? Right side ? Someone recently posted a diagram and pics of their side mounted fighter pilot set-up ? ???
Author:  Ryan Allen [ Wed Mar 11, 2015 10:11 pm ]
the new fandangle is going on the left side. I must have missed the recent postings. I'll go review the posts. thanks for the tip.
Author:  Rich Brazell [ Wed Mar 11, 2015 10:39 pm ]
Go to search and type in throttle quadrant . Bob Highley has pics and you'll find a link to Bill Williams NL write-up . BOOM !
Author:  Ryan Allen [ Thu Mar 12, 2015 6:34 am ]
Thank you Rich. I did find a throttle quadrant post with outstanding pictures of the quadrant itself. But what I really want to see, is the bellcranks and how you mounted your bellcranks to the motor.
Author:  Bill Williams [ Thu Mar 12, 2015 6:40 am ]
I used rod ends on all three cables. Look at how the marine installations attach there cable ends. No bellcranks used. Used Teleflex cables made to length
Author:  Rich Brazell [ Thu Mar 12, 2015 8:31 am ]
Just like Bill said . I used rod end bearings also with standard ACS push/pull cables threaded on both ends . No bell cranks involved . My quadrant is small enough that it could be "side mounted . " Don't look for my quadrant in any catalog , I made it from a solid block of acrylic and the control levers were also made and bent in a vise . I ended up making one because I couldn't find one small enough . I have Muey Macho Hands ! The quadrant has worked perfectly for over 200 hours ! :o Sorry I don't have and pics of the assembly process . :'(
Author:  fytrplt [ Thu Mar 12, 2015 4:05 pm ]
Les Conwell turned his carb around to negate the need for bellcranks. As my Lycoming engineer buddy said, "The engine doesn't know which way it is going. " Les has flown this configuation over 2000 hours.
Author:  Ryan Allen [ Thu Mar 12, 2015 7:11 pm ]
Dang, that a good idea about the carb. I also realized that if I will attach the linkage to the quadrant levers above the rotation point of the quadrant levers that I will indeed not need bellcranks. Thanks for all the tips.
https://www.phpbb.com/
