| Refinishing Wood Props http://thorp18.com/thorpforum/viewtopic.php?f=35&t=6963 |
| Author: | SHIPCHIEF [ Mon Mar 19, 2012 10:03 am ] |
| Post subject: | Refinishing Wood Props |
Here is an interesting link on refinishing wood props: http://www.thompson-aero.com/index.php? ... &Itemid=32 Here is the link to Thompson-aero's home page on wood props: http://www.thompson-aero.com/index.php? ... &Itemid=32 |
| Author: | mgon [ Mon Apr 16, 2012 2:54 pm ] |
| Post subject: | Re: Refinishing Wood Props |
Good information for wood prop owners, I'm wondering what the best epoxy for wood would be? |
| Author: | SHIPCHIEF [ Mon Apr 16, 2012 4:49 pm ] |
That's a good question, and one I'm dealing with. I have a Hendrickson 68x68 prop, and it has fiberglass wrapped tips. One blade has a fiberglass delamination it the trailing edge, about 3/8" chord, and 4" span, about 2/3 of the way out the blade. I'm considering heating & reforming the 'glass, then rebond & clamp. I've been using West System Epoxy for all my fairings & plenums on the RV-8, so that's what I'll use. After that, varnish with whatever the logbook indicates was used during refinish maintenance in the past. I think it was eurethane varnish. If the reform & rebond doesn't hold up, I'll have to remove the offending little patch of glass, clean to wood, and lay in a new patch, then refinish and ballance etc. |
| Author: | ljkrume [ Tue Apr 17, 2012 1:28 pm ] |
You can reform fiberglass with heat? I'd like to get the warps out of large surfaces on my cowling and wing tips. Anyone, please tell me more. Les Krumel, Albuquerque |
| Author: | Rich Brazell [ Tue Apr 17, 2012 3:21 pm ] |
Les: I am not a "fiberglass man", but I have had some success with heating the stuff and taking out a few "bumps." I think the key is just enough heat to bend and or shape it and not enough to start the stuff to separate. I would heat it and place a couple of pieces of wood on each side and clamp it until cool. I hate the stuff and would pay double or triple for a carbon fiber cowl, tips and pants with a nice smooth finish ! RB |
| Author: | SHIPCHIEF [ Sun Jun 03, 2012 9:12 pm ] |
I tried heat from a heat gun. I didn't like the results. However, my prop had a unique delamination. The trailing edge of the fiberglass cover on the tip had come loose, the delamniated section was about 1/2" wide & 4" long, It started about 1/2" outboard of the inner edge. The prop had been operated in this condition, so centrifugal force had acted on the loose edge. When I applied heat, the oxidized epoxy just turned brown. It didn't really get sticky or anything. Also, a tear appeared near the inboard edge mentioned above. I carefully cut out the delaminated strip with a dremel tool using a cut off wheel, and hand worked the wood with needle files until I had clean smooth wood and no loose or frayed fiberglass edges. I then used West Systems Six-ten (610) which is dispensed from a caulking gun tube. I didn't use the mix nozzle, the amount was so small. It mixes to a consistency of vaseline or a bit thicker. It stayed in place on the prop, and formed well with wood hobby sticks (tongue depressors to us old guys). A day later, I filed and sanded the high spots, then brushed on some Minnwax Spar varnish, looks fine. A week later, my hangar mate scratched the trailing edge of the other blade while putting his plane away, so I got to do it a second time. Now I have Minnwax Spar Varnish in a spray can for less than $10. I'll try that next time. |
| Author: | Rich Brazell [ Sun Jun 03, 2012 10:26 pm ] |
Hangar mate owes you case of beer ! Expensive beer ! RB |
