It is currently Wed Nov 11, 2026 10:15 am
flychris
 Post subject: Exhaust hangers
PostPosted: Thu Mar 15, 2012 9:06 pm
Got one sweet 4 pipe set up from custom exhaust! I'm going to have the only smooth bottom cowl thorp and still have a carb I think! It's a forward facing carb (HA-6) anyways thinking I should have everything done and ready to run but this tomorrow. Trying to make sun n fun!!! Question is how did you make you exhaust hangars? I've seen some just looking for something quick and easy (yeah right)
Thanks
Chris
 Post subject: Re: Exhaust hangers
PostPosted: Thu Mar 15, 2012 9:55 pm
I put an Adel clamp around the lower gear cross bar...don't remember the size ? Then attached a piece of reinforced rubber strip (the kind they use to make muffler hangers) to the Adel clamp and then attached that to the supplied steel clamps from Custom Aircraft that go around the pipes. You don't want a rigid set up. It needs to "float" with the ball joint on the exhaust. Thought I had a pic, but no.
PostPosted: Thu Mar 15, 2012 10:27 pm
I used the aramid fiber fan belt out of my 90 Chevy pickup, had an old one laying around it is the flat belt. Will handle the heat, they don't stretch, they don't break. Adel clamp, 2 no10-32 Stainless cap screws, nylocs and it was done in 30 min. Use a good shape set of snips, aramid fiber is tough stuff...Dan
PostPosted: Thu Mar 15, 2012 10:54 pm
I suppose I could have used the fan belt off my 1950 Ford 8-N tractor, they last 30 years ! I should know I just replaced one !
flychris
PostPosted: Fri Mar 16, 2012 6:47 am
Dan,
Any pics?
Thanks
PostPosted: Fri Mar 16, 2012 6:58 am
Hey Chris, where in Atlanta are you? I'm staying the next few days at my brothers in Tucker. My Thorp is at LZU. Call me 8639448779 Bill N30WW
PostPosted: Fri Mar 16, 2012 7:06 am
In one of the newsletters Dick Penman submitted a really nice sketch of his exhaust hangers.... he cut tabs out of a tire sidewall. one end of the rubber was bolted to the A-frame cross tube, the other to a stainless strip. The stainless strip was clamped to the pipe.
flychris
PostPosted: Fri Mar 16, 2012 7:07 am
Bill,
I'm at Tara 4a7 its about a 15 min flight from where you are. I'll be here all day working if you want to stop by.
Chris
4046973069
PostPosted: Fri Mar 16, 2012 7:58 am
I'll try and get a pic of my exhaust hanger this AM. A/C is at home for it's annual.
PostPosted: Fri Mar 16, 2012 9:14 am
There was also a picture of a really nice bent up wire affair in another newsletter. It had a couple of spring loops (like on a clothes pin) between the pipe and the cross-tube. Shouldn't take more than a half hour to make a pair out of welding rod.
Another alternative is to just wrap a bunch of coathanger wire around the pipes and the cross tube. Don't ask me how I know.
PostPosted: Fri Mar 16, 2012 10:18 am
Make two small loops from 1/8 aircraft cable , nicopress the two ends together, twist in a figure eight and use hose clamps to secure.
PostPosted: Fri Mar 16, 2012 12:12 pm
I like the tire rubber route. The bent up solid wires tend to fatigue and break.
Oh and Chris dont want to rain on your parade because you're doing a great job getting that bird back in operation but several of us have smooth cowls and carbs. A few of us have horizontally inducted sumps others have 90 deg elbows and bolt the ha6 to that. But your thingin the right way the smooth no scoop cowl sure does the airplane right!
PostPosted: Fri Mar 16, 2012 1:43 pm
Here's how I did the hangers. Took about 15 min. each to make, Adel clamp, piece of reinforced rubber, a small piece of of angle and a few AN-3 bolts and high temp. nuts. The metal "loops" around the pipes came with the exhaust.
PostPosted: Fri Mar 16, 2012 3:18 pm
I just replaced my hangers with a piece of conveyor belt. Truck mud flap might work too.
PostPosted: Fri Mar 16, 2012 3:20 pm
Can we get some photos of these slick cowls?
[ Time : 0.419s | 11 Queries | GZIP : On ]
