| IO-360-BIA http://thorp18.com/thorpforum/viewtopic.php?f=35&t=6746 |
| Author: | Ryan Allen [ Wed Aug 17, 2011 10:11 am ] |
| Post subject: | IO-360-BIA |
Will an IO-360-BIA fit in the standard T-18 engine compartment? A friend has one he may sell to me but I dont want it if it wont fit. Anyone have any insight? Ryan |
| Author: | Fraser MacPhee [ Wed Aug 17, 2011 10:18 am ] |
If it's an angle valve, your cheeks will need to be squirreled as the standard cheek will not fit over the valve covers. |
| Author: | Ryan Allen [ Wed Aug 17, 2011 6:24 pm ] |
I was afraid of that. Thanks Frasier. |
| Author: | fytrplt [ Wed Aug 17, 2011 6:33 pm ] |
The angle valve engine is significantly heavier so by the time you put the necessary weight in the tail for proper weight and balance, you will not gain anything. |
| Author: | leewwalton [ Wed Aug 17, 2011 8:05 pm ] |
B1A is an injected parallel valve motor, should be fine. |
| Author: | Ryan Allen [ Thu Aug 18, 2011 8:17 am ] |
I guess I should just go measure the thing and be done with it. I appreciate all the info. |
