It is currently Sat Apr 27, 2024 10:26 pm
dcuke
 Post subject: flywheel problem
PostPosted: Mon Jun 13, 2011 6:31 pm
I have an O-290 powerplant that I am putting in my t-18. The log book that I have on this says that the crank was replaced with a O-320 crank. I needed a flywheel (assuming a o320) for this and found that someone on the forum had a O-320 flywheel for sale. I had it shipped to me and when I tried to fit it to the crank the holes on the flywheel are just a tad too big. the holes on this flywheel are 3/4", but my bushing flanges on the crank are about 5/8" O.D.
Are there different sized flywheels for the o-320 out there with different diameter holes for the bolts? I am a somewhat perplexed at what to do. Could there be some type of spacer that is supposed to fit there? I only have a o-290 parts and service catalog.... but nothing for the o320. Everything has been simple for matching parts until I got to this crank.
There are also 2 part numbers on this flywheel. The original etched numbers are #71328. Then right beside these numbers someone has penciled in 68867 (modified?).
If anyone has some insight, I would really appreciate it.
Dean Cuke
Visalia, California
N772DM
KVIS
PostPosted: Tue Jun 14, 2011 3:41 am
I'm in Boston and cannot check the part numbers, sounds like someone modified a 0320 flywheel to fit an 0360. The 0320 uses 7/16" bolts and the 0360 uses 1/2" bolts using larger lugs
PostPosted: Tue Jun 14, 2011 7:29 am
I checked on that for Bill, and he is of course correct ...
71328 is an old PN for an 0-360 (superceded by 72565)
68867 is an 0-320 PN
That explains the oversized holes.
dcuke
PostPosted: Tue Jun 14, 2011 8:15 am
That answers my question. Thanks Bill & Lee for your help. I really appreciate it.
Dean Cuke
Visalia, California
N772DM
KVIS
[ Time : 0.345s | 13 Queries | GZIP : On ]
