| Ign wire holder/standoffs http://thorp18.com/thorpforum/viewtopic.php?f=35&t=6437 |
| Author: | Rich Brazell [ Fri Dec 10, 2010 9:36 am ] |
| Post subject: | Ign wire holder/standoffs |
If you need a "cheap" (not cheaply made) ign. wire holder/standoff to organize/protect your wires, try this. Made from scrap angle and 0.020 sheet. I used a unibit to drill the holes one size larger than the required hole for the grommet. Round off the corners to make grommet insertion easier. Drill and tap for a 4-40 screw. Cut one side of the grommet to slip over the ign wire. Attach a nut plate for easy attach/removal. Sure beats the high cost of using store bought holders. [8D] RB NX115RX Image Insert: ![]() Put File Caption Here |
| Author: | N89BJ [ Sat Dec 11, 2010 1:15 am ] |
Great idea. Thanks for sharing. |
