It is currently Thu Sep 24, 2026 2:05 pm
Chasr263
 Post subject: f911 propeller bolts
PostPosted: Fri Sep 27, 2013 4:59 pm
Just got a set of f911 bolts, nuts, washers for my Warnke prop from Saber in Grandberry, TX. I was wondering if anyone is using grade 8 or better prop bolts? I am interested in opinions about these stronger but more brittle bolts as this is my first experience with f911. Thanks Chuck R.
 Post subject: Re: f911 propeller bolts
PostPosted: Fri Sep 27, 2013 5:55 pm
Got my prop extension and bolts from Saber . No problems . 8)
PostPosted: Fri Sep 27, 2013 8:07 pm
Do not go cheap on prop bolts!! Sam knows what he is doing.
PostPosted: Fri Sep 27, 2013 10:34 pm
Yes he does ! ;)
Pacer 20
PostPosted: Tue Oct 01, 2013 8:35 pm
Is is possible to find aviation bolt to install this propeller?
I have to do some research about the F911 bolt. I'm curious!
Thierry
French Canadian T-18
C-FPVE #091
PostPosted: Tue Oct 01, 2013 9:12 pm
Not sure what prop ? Vans sells prop bolts . :o
Pacer 20
PostPosted: Tue Oct 01, 2013 9:41 pm
All kind of propeller. I just try to understand what is the advantage to install commercial hardware versus aviation bolt. The price I think.....
Thierry
C-FPVE #091
PostPosted: Thu Oct 03, 2013 5:42 pm
The advantage may be that AN/prop bolts bolts are traceable . You know who made the bolt . Commercial bolts could come from anywhere , including Hop Sing from Bonanza ! ::)
Victor J Thompson
PostPosted: Thu Oct 03, 2013 6:49 pm
Images: 70
Rich: I try not to buy my parts from Hop Sing,....
Victor J Thompson
C-GIRQ
In memory of Dad
PostPosted: Sun Oct 06, 2013 7:46 pm
I ordered a set of f911 bolts, nuts, etc for 66WT. I'll use them to install the Wood Aymar Demuth Prop I have for this Thorp. In reading on the Saber site the only part I'm not sure of is the big push to go for a larger flange on a prop extension. I don't have the benefit of an Engineering Degree, but it seems to me that most of the grip would be accomplished by the drive lugs in the extension and not the increased surface area of the flange. Anyways, I have 4" prop extension that will work just fine. They have for years...As far as the f911 bolts - I know guys that have been flying behind them for 15+ years with no issues. Order with Confidence!
[ Time : 0.118s | 9 Queries | GZIP : On ]
