It is currently Thu Sep 24, 2026 1:17 pm
 Post subject: Wide deck 360
PostPosted: Sat Sep 08, 2012 4:08 pm
Does anyone know if a wide deck 0-360 will fit inside a standard T-18 cowl? Any "gotchas" with a wide deck engine and the Thorp airframe?
 Post subject: Re: Wide deck 360
PostPosted: Sat Sep 08, 2012 4:20 pm
Wide deck and narrow deck motors are dimensionally the same for all practical purposes. Angle valve 0360 s are a different story though, theyre not recommended.
PostPosted: Sat Sep 08, 2012 5:16 pm
oh, ok. thank you. much appreciated.
PostPosted: Sat Sep 08, 2012 6:50 pm
As Lee pointed out the dimensions are the same, the difference is in the cylinder bases. Why they call them wide deck/ narrow deck is a mystery. The narrow deck cylinder base flange is 1/4" thick and uses a re-inforcement plate the hold the cylinder. The wide deck has a 3/8" thick base and bolts on directly.
Victor J Thompson
PostPosted: Sun Sep 09, 2012 7:29 pm
Images: 70
Bill: thought there was more differences so I consulted a reference that I have (Paul McBride, recognized worldwide as an expert on engines, retired after almost 40 years with Lycoming).
http://www.generalaviationnews.com/2009 ... k-engines/
536
WD cylinders are retained to the crankcase using a standard hex nut, while a ND cylinder utilizes a barrel type, internal spline nut with a
Victor J Thompson
C-GIRQ
In memory of Dad
PostPosted: Mon Sep 10, 2012 5:45 am
Good article. I think the bolt patterns are different on the two engines as there was a change on how the crankcase through bolts were installed. He did not answer the question "why they called them WD vs ND?" I guess Lycoming was referring to the cylinder bases.
PostPosted: Mon Sep 10, 2012 6:44 am
Paul was referring to the "deck" of the cylinder. Cases are dfferent, as well in the way the alternator is attached. As Lee said, the dimensions are the same.
[ Time : 0.114s | 9 Queries | GZIP : On ]
