It is currently Thu Sep 24, 2026 1:21 pm
 Post subject: Lean of peak
PostPosted: Sun Jan 29, 2012 10:14 pm
This may seem silly but will one of you in the know explain "lean of peak" operations please? I'm getting numerous conflicting opinions at the local round table.
 Post subject: Re: Lean of peak
PostPosted: Mon Jan 30, 2012 7:35 am
Lee,
Try this link from EI Instruments: http://www.buy-ei.com/Information/Pilots%20Manual.pdf
PostPosted: Mon Jan 30, 2012 8:03 am
Exactly what I needed, thanks Bob!
PostPosted: Sun Apr 01, 2012 5:12 pm
For another view of the leaning argument I would recommend the following reading:
Mike Busch (The Savvy Aviator) on leaning, note he has a Cessna twin and both engines are close to 100% over the recommended TBO and still going strong. http://www.avweb.com/news/savvyaviator/savvy_aviator_59_egt_cht_and_leaning_198162-1.html
Also for your reading pleasure is a series of articles by John Deakin on "Where should I run my engine"
http://www.avweb.com/news/pelican/182179-1.html Part 1
http://www.avweb.com/news/pelican/182176-1.html Part 2
http://www.avweb.com/news/pelican/182583-1.html Part 3
http://www.avweb.com/news/pelican/183094-1.html Part 4
For me, I would run my engine lean-of-peak if I could, carburetor doesn't work to well lean of peak. I also don't run my CHTs higher than 380, I have a red line set on my monitor at 400.
I would also point out that the big radial engines were routinely run lean-of-peak or the airliners would not have made it across the pond (too high of fuel flow).
PostPosted: Mon Apr 02, 2012 11:39 am
Funny. All LOP discussions devolve to the emotional.
PostPosted: Mon Apr 02, 2012 12:17 pm
LOL at Dick - indeed - With an O-320 and a projected average of 75 hours of flight time per year ,I emotionally resolve to operate my motor slightly rich of peak at all times with the occasional momentary over lean to clean the plugs when deemed emotionally necessary.
Having said that, a seasoned colonel once told me to lean for airspeed.
If I had dual 540s to feed and manage, I might be a little more concerned.
[ Time : 0.103s | 9 Queries | GZIP : On ]
