| Hero Member |
Joined: Tue Oct 20, 2009 8:07 pm Posts: 1166 Images: 2 Location: Lakeland, Florida, USA
Hank,
You bring up a good point. Since you have an early Thorp, your mount may have been built to the dimensions that John Thorp included in the motor mount drawings. The early newsletters spoke to this. Later vendor supplied mounts used ready made rings with standard mount cups. You will have to shim the new spacer as it will be too short. I suggest washers for starters. The supplied spacer has a torsional vibration isolator molded into it and is part of the system, thus you shouldn't just eliminate it. These should be installed to be alligned radially to dampen the radial vibration of the engine. You will note that the bicuits have a hole to insure proper orientation in the motor mount. Most of our mounts don't have the necessary pins to make this work so you will have to insure allignment upon installation. Good luck!
_________________ Bob Highley
