It is currently Thu Sep 24, 2026 1:17 pm
PostPosted: Fri Dec 10, 2010 9:36 am
If you need a "cheap" (not cheaply made) ign. wire holder/standoff to organize/protect your wires, try this.
Made from scrap angle and 0.020 sheet.
I used a unibit to drill the holes one size larger than the required hole for the grommet. Round off the corners to make grommet insertion easier. Drill and tap for a 4-40 screw. Cut one side of the grommet to slip over the ign wire. Attach a nut plate for easy attach/removal. Sure beats the high cost of using store bought holders. [8D]
NX115RX
Image Insert:
Put File Caption Here
N89BJ
PostPosted: Sat Dec 11, 2010 1:15 am
Great idea. Thanks for sharing.
[ Time : 0.102s | 10 Queries | GZIP : On ]
