Stall strips
http://thorp18.com/thorpforum/viewtopic.php?f=33&t=6991
Author:  flychris [ Wed Apr 11, 2012 5:09 am ]
Post subject:  Stall strips
Where to get them and where exactly do they go on the inner wing?
Thanks,
Chris Cox
Author:  leewwalton [ Wed Apr 11, 2012 7:44 am ]
Post subject:  Re: Stall strips
Chris,
Have a look at newsletter 71.
Author:  leewwalton [ Wed Apr 11, 2012 7:47 am ]
Oops! Make that newsletter 82!
Author:  New2T18 [ Sun Nov 04, 2018 11:36 pm ]
New to the forum. Looking at purchasing a T18 and doing research on the stall strip. How do I find newsletter 82?
Thanks in advance
Author:  Jeff J [ Mon Nov 05, 2018 6:47 am ]
Good question. They should be on the main website: http://thorp18.com/index.php?option=com ... Itemid=159
but they didn't come up. They were on the old forum with all of them scanned into 2 files but I can't seem to find the old forum anymore either.
NL82.pdf [1.18 MiB]
Downloaded 2307 times
Author:  New2T18 [ Mon Nov 05, 2018 12:38 pm ]
Thank you very much. Very interesting and I'm not sure what the negative could possibly be, or am I missing something. They sound very straight forward to install.
I assume these are made from solid stock and machined? Or could they be as simple as 3/8" x 3/8" aluminum angle for the material, granted the angle material would create a very small air gap between the leading edge, but is that even an issue? It seems they would mount pretty tight.
Author:  Jeff J [ Mon Nov 05, 2018 1:51 pm ]
There is a sketch on the next page(5) of the news letter that implies solid stock by giving a 1/2" radius to match the leading edge.
Author:  Jim Mantyla [ Mon Nov 05, 2018 4:13 pm ]
Guys,
I made mine from 3/8" aluminum angle. I ground the edges so that there was virtually a sharp edge where they touched the leading edge. I stuck them on with a silicone adhesive. It was black and so is my plane so there was no appearance issues. I now have a stick shake just before the stall.
Regards,
