control stick boot
http://thorp18.com/thorpforum/viewtopic.php?f=30&t=8378
Page 1 of 1
Author:  rjaeger [ Wed Jun 05, 2019 6:38 pm ]
Post subject:  control stick boot
I remember reading a discussion in the past regarding making a boot to cover the control stick area, any suggestions please?
Author:  Rich Brazell [ Wed Jun 05, 2019 10:32 pm ]
Post subject:  Re: control stick boot
I used the same heavy duty material that covers the side panels next to the seats . I shaped it like an ice cream cone and had a gal with a heavy duty sewing machine sew up the sides . Made the base to fit the arc of the walking beam for clearance and secured the "cone" to the base with a doubler plate on the top and bottom . Boots have been in place for almost 10 years with no sign of wear and take up a lot less space than the auto shift type boots that some folks use .
Author:  rjaeger [ Thu Jun 06, 2019 5:57 am ]
I built my base up about 1/4 of an inch but haven’t fastened it yet. Didn’t know if you ever have to get in there again which would dictate riveting or nutserts. How are the trim plates attached to the flooring ? Thanks for the reply and pics.
Author:  fytrplt [ Thu Jun 06, 2019 6:28 am ]
Yes, you will need to get into that space for inspection. Also, I made the right stick removable (pip pin) for passenger comfort.
Author:  Rich Brazell [ Thu Jun 06, 2019 9:10 am ]
Bob is right . I take the boot bases and pull them aside for conditional inspections . While I am in there looking around I shoot a short spray of lube on the walking beam pivot points . The bases are attached to the "floor area" with #6 ( I think they are #6 , maybe #8 ?) stainless steel machine screws .
Author:  Jeff J [ Sun Nov 29, 2020 9:38 am ]
The impending colder weather has me thinking about the frozen fingers I get from the draft coming up the stick starting about this time of year. Searching the forum found some discussion but dead links to the pictures (even altering the address didn’t help). I don’t have access to a heavy duty sewing machine. I guess I could hand sew some but what automotive boots are people using? The ones I have looked at don’t look like they would fit over the stick.
Author:  Ryan Allen [ Sun Nov 29, 2020 9:48 am ]
I use one from Autozone trimmed, cut and tailored to fit.
Author:  ljkrume [ Sun Nov 29, 2020 12:01 pm ]
Hi Jeff,
Heavy duty sewing machine maybe not necessary for your boot, depending on material. Thin material is good so not to move the stick on its own. Good to have them to keep anything from falling down and jamming other things ‘up’. I used black naugahyde in a cone as Rich said, and likewise, a thin plate at base to hold it down. Add a zipper up the side instead of a seam and it’s easy to slip on and off over the grip.
I came across a bag of 6-32 PEM nuts and use them throughout the airplane for non-structural items like this. Highly recommended for ease of installation, just a 3/16” hole and squeeze one in on back side with a clamp, vise (or hammer). They have serrations to lock them in. Better grip than sheet metal screws and not likely to strip out (sorry Rich).
Les
Author:  Hagle347 [ Sun Nov 29, 2020 9:30 pm ]
Look on Ebay, 218TH has black suede covers installed. The shifter cover had a plastic insert- once removed it was the ideal size for the stick. All I had to do was fabricate how it would be attached to the airframe. There may still be interior photos on the build thread for 'Terrys Keeper"
Author:  Rich Brazell [ Sun Nov 29, 2020 10:46 pm ]
I used an eldery lady that ran her own taylor shop in side a laundry . She had a heavy duty sewing machine and only charged me me a few bucks to sew up both boots . The material was HEAVY duty truck upholstery material . :P
Author:  Ptbob484 [ Wed Jun 01, 2022 9:09 am ]
These from Amazon work great and slip right over.
Spectre Performance 6285 Universal Shift Boot
https://a.co/d/15015az
https://www.phpbb.com/
