It is currently Fri Oct 23, 2026 8:56 pm
PostPosted: Fri Nov 22, 2013 9:55 pm
how do you secure a throttle quadrant to the airframe? I'm thinking about putting in a throttle quadrant, but the only way I can think of securing it (without drilling holes in the longeron) would be to make some sort of cantilevered connection to the panel.
mgon
PostPosted: Fri Nov 22, 2013 10:22 pm
Its not a quadrant, but this has worked out for me.
MG
PostPosted: Sat Nov 23, 2013 6:16 am
I thought about doing that, but I wanted to try and not drill any new holes in the airframe. I do like to the look of it though.
PostPosted: Sat Nov 23, 2013 7:11 am
I drilled two #10 holes in the longeron. Has worked for 2700 hours.
PostPosted: Sat Nov 23, 2013 7:24 am
Two #10 holes in the longeron and a short piece of angle to bolt the quadrant-1300 hours
PostPosted: Sat Nov 23, 2013 8:09 am
ok, well, I guess I see a trend here. thanks.
PostPosted: Sat Nov 23, 2013 11:21 am
By the way, you can drill into structural parts of the airframe as long as those holes are properly taken care of. Cleaning, deburring, and riveting would be a proper way to take care of it.
Ps don't go wild, tho.
[ Time : 0.288s | 14 Queries | GZIP : On ]
