It is currently Fri Oct 23, 2026 8:56 pm
Tim Brown
 Post subject: tablet mount
PostPosted: Fri Jul 18, 2014 10:40 am
I just ordered a nexus 7 to replace my phone for running naviator in the airplane.. i was Velcroing the phone to the panel but the nexus is bigger and heavier. .. i would like a mount that attaches to the panel...
Who's using what?
Thanks
 Post subject: Re: tablet mount
PostPosted: Fri Jul 18, 2014 3:23 pm
Here's what I'm using Tim ...
http://www.rammount.com/NewProducts/Goo ... fault.aspx
Tim Brown
PostPosted: Sat Jul 19, 2014 7:22 am
Thanks Lee.... do I understand correctly. ...
its just a suction cup holding the arm on the panel...
it seems destined to fail and fall to the cabin floor.. :-\
Any pictures?
PostPosted: Sat Jul 19, 2014 8:21 am
Tim, That's a RAM mount ... they offer numerous attach methods, take your pic. Mine is mounted to the panel with 4 MS and nutplates.
Lee
Tim Brown
PostPosted: Sat Jul 19, 2014 11:49 am
Roger.... checking again... Thanks
bcabebe
PostPosted: Sun Jul 20, 2014 3:21 pm
I have a Nexus 7 (2nd edition 2013). I printed a two piece, slide on case and put "velcro" on the back of each piece. Then I cut and bent aluminum, mounted those pieces to the panel and put "velcro" in the appropriate spots. I slide the case on to the tablet and then press the tablet & case into place on the mount.
The "velcro" is actually a Scotch brand All Weather Fastener that I bought at Target. It's a little tricky to get the tablet & case back off the mount, you just have to go slow and be patient.
Brian Cabebe
N39JP
PostPosted: Sun Jul 20, 2014 3:51 pm
I used a tablet mount like the one on Ebay Item 390890612043. I removed the suction cup, using a 10-32 screw mounted it to the panel. Hplds my Samsung Tab 7" great.
[ Time : 0.324s | 10 Queries | GZIP : On ]
