| Print for Main&Rear Beams, Outer Wing, #314 rev. A (S18) http://thorp18.com/thorpforum/viewtopic.php?f=3&t=9131 |
| Author: | cw21f [ Fri Feb 07, 2025 9:17 am ] |
| Post subject: | Print for Main&Rear Beams, Outer Wing, #314 rev. A (S18) |
Was getting ready to cut the tapers in the caps, but I have hunted high and low and can not seem to locate the #314A drawing for the Main & Rear Outer S-18 wing beams. Would anyone be able to help me by providing a picture or scan of this single (11"x17") page? Please and thank you. Chris |
| Author: | Rv3maker [ Sat Feb 08, 2025 11:57 am ] |
| Post subject: | Re: Print for Main&Rear Beams, Outer Wing, #314 rev. A (S18) |
Here is a copy. Although, mine doesn't say "Rev A". Rob
| Author: | Thorp Aircraft [ Thu Mar 06, 2025 12:06 pm ] |
That is not a current revision drawing as there is a 314 Rev A. Please keep in mind that these drawings are protected intellectual property of Thorp Aircraft. Chris, Do you have a set of plans? I do have all the current revision drawings. Give me a call to discuss the current revision drawing. Alex Pearson Thorp Aircraft 210-365-3374 |
| Author: | Rv3maker [ Fri Mar 07, 2025 2:20 pm ] |
Alex, Can you summarize what the Rev A change notes were from the drawing? Rob |
| Author: | Thorp Aircraft [ Sat Mar 08, 2025 9:08 am ] |
I am seeing additional detail on rivets in 3 places on the drawing and a Note 2 to reference drawing 228-1 for Spar details. |
| Author: | Rv3maker [ Mon Mar 10, 2025 4:05 pm ] |
Thanks Alex. Brings up another point. Is there a current list of every drawing sheet and the latest revision? I have S-18 SN046 plans and it would be good to compare current drawings I am working from to make sure there are no revisions that are needed etc. I know many of the drawing updates were from newletters etc, but a reference sheet or spreadsheet would be awesome! Rob |
