| Inspection Hole Location http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8815 |
| Author: | James Grahn [ Tue Feb 13, 2024 12:19 am ] |
| Post subject: | Re: Inspection Hole Location |
Have you looked at AC43-13? It is a huge wealth of information. This will be addressed in this publication. Cubes |
| Author: | Steve H [ Tue Feb 13, 2024 9:07 am ] |
Hi Cubes. Yes, I have studied AC43. There are no references to installing inspection plates that I can find. 4-58. REPAIR METHODS AND PRECAUTIONS FOR ALUMINUM STRUCTURE, para. e., references making flush patches in accordance with Figure 4-16. The patch would be installed on the bottom surface the skin and a filler riveted onto the patch flush with the skin. FIGURE 4-16. Typical repairs of stressed sheet metal coverings. In the right side patch example of the upper drawing in figure 4-16, the doubler ring for the inspection plate assembly would the stiffener to back up the seam of the patch. The inspection plate would the patch plate. However, the inspection plate will not overlap the skin, just the doubler. The doubler ring, inspection plate, rivet size and spacing are to match the surrounding skin pattern. The pattern of the inspection plate screws would have to match the rivet pattern, and screws would have be structural to be used in place of rivets. It's not readily obvious if the stiffener has a flange. The bottom drawing in figure 4-16, referencing the patch A to D, over a hole in the skin, really doesn't apply since there is no doubler involved. The installation of circular patches are don't seem to apply to this. The video showing installing the Piper inspection plate AD shows installation of the doubler ring (which is not flanged) with single row of rivets. However it isn't installed in the middle of the span of the wing. |
| Author: | Rv3maker [ Tue Feb 13, 2024 11:37 am ] |
Do you have the S-18 drawings? Assuming you do, I would consider just making them the same as depicted on drawing 300L, parts 300-3 and 300-4 and locating them where you would like. Rob |
| Author: | Steve H [ Tue Feb 13, 2024 6:40 pm ] |
Hi Rob. I do have the plans so I'll compare them with what I have. Thanks. |
