| Flap mount bushing - Help with finding the part http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8810 |
| Author: | Ryan Allen [ Thu Dec 14, 2023 1:31 pm ] |
| Post subject: | Re: Flap mount bushing - Help with finding the part |
it appears my drawings show you are supposed to use the same bushing as what is used for the rudder bushing. Mine is dwg 581 for that bushing. How did you attach pictures? I tried to do that and it tells me failed all the time |
| Author: | Rv3maker [ Thu Dec 14, 2023 2:49 pm ] |
Hey Ryan, I will check that and look for the reference. If you can get a pic or point to where it is referenced that would be great! For pics, I just have jpegs and use the "add image to post" link right below the text box. Seems to work if I just leave the default options (i.e. don't try to resize) and pick from file on my computer. ***EDIT*** - checked the 581 drawing - that seems to be it. Thanks! I believe I saw these on Thorp Central parts listing and couldn't correlate them to the flaps - now it make sense! Rob |
| Author: | James Grahn [ Thu Dec 14, 2023 2:58 pm ] |
They were called out as 555 on the T18 drawings. Same part, just made from different material. We stock them as 581. Cubes |
| Author: | Rich Brazell [ Thu Dec 14, 2023 7:46 pm ] |
Pretty sure the original material for the bushings was a Phenolic material . I believe I still have one or 2 of the original bushings that came with the partially completed project I bought back in 1984! When you could no longer get the Phenolic bushings I got the "Nylon Bushings" from Ken Knowles or Mike Archer ? That is all . RB OUT ! RBNX115RX |
| Author: | fytrplt [ Fri Dec 15, 2023 7:07 am ] |
I made mine out of stainless steel. Comparable with aluminum and doesn't imbed grit like the plastics do. As for the ones for the flaps, I made several with offset center holes so I can rotate them on assembly for final adjustment. |
| Author: | fytrplt [ Fri Dec 15, 2023 7:59 pm ] |
Just tightened. Did put a punch mark on the collar for reference. |
