| Aileron Skin http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8753 |
| Author: | rrobut [ Tue Jan 10, 2023 5:44 am ] |
| Post subject: | Aileron Skin |
For you guys that have skinned the ailerons by folding the trailing edge does it significantly reduce the aileron stick forces. |
| Author: | david read [ Tue Jan 10, 2023 10:24 pm ] |
| Post subject: | Re: Aileron Skin |
Yes. I have flown both and as speed increases there is a significant difference. When I built I folded mine because I liked the looks and they were easier to keep the trailing edge straight but it does make more of a challenge to put the stiffeners inside |
| Author: | James Grahn [ Wed Jan 11, 2023 12:41 am ] |
You can accomplish the same results by using a thicker trailing edge strip. Cubes |
| Author: | rrobut [ Wed Jan 11, 2023 6:35 am ] |
Thanks for the replies and also Cubes for the constant speed prop info yesterday |
