It is currently Sun Nov 15, 2026 2:30 am
rrobut
 Post subject: Aileron Skin
PostPosted: Tue Jan 10, 2023 5:44 am
For you guys that have skinned the ailerons by folding the trailing edge does it significantly reduce the aileron stick forces.
 Post subject: Re: Aileron Skin
PostPosted: Tue Jan 10, 2023 10:24 pm
Yes. I have flown both and as speed increases there is a significant difference. When I built I folded mine because I liked the looks and they were easier to keep the trailing edge straight but it does make more of a challenge to put the stiffeners inside
PostPosted: Wed Jan 11, 2023 12:41 am
You can accomplish the same results by using a thicker trailing edge strip.
rrobut
PostPosted: Wed Jan 11, 2023 6:35 am
Thanks for the replies and also Cubes for the constant speed prop info yesterday
[ Time : 0.179s | 9 Queries | GZIP : On ]
