| Rivet Spacing Main Beam Inner Wing http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8673 |
| Author: | rrobut [ Wed Jan 19, 2022 5:52 am ] |
| Post subject: | Rivet Spacing Main Beam Inner Wing |
Deciphering the plans on Drawing 227. Called out are 144 AN470 AD 4-8 rivets between BL18.0816 and BL41.375 Does this mean there are 36 rivets on the top Spar Cap and 36 on the bottom angle cap at each end. Thanks for the help Rob |
| Author: | Ryan Allen [ Wed Jan 19, 2022 7:21 pm ] |
| Post subject: | Re: Rivet Spacing Main Beam Inner Wing |
Rob My DWG 227 only shows 18 rivets between BL18 and BL41. I may have an old set of plans. I was able to come up with 144 by counting the 18 rivets called out in my plans on the top cap (between BL 18 and BL41), and then I doubled that number to get 36 rivets across the top cap (for one side, I assume to address the smoking rivet issue). Then multiply 36 by 4 for each upper and lower cap to get to 144? Im sorry, thats really not any help at all.... |
| Author: | fytrplt [ Sat Dec 09, 2023 7:36 pm ] |
I have built both T and S wings. Double row on each version. On the T, I had already single riveted the skins to the spar. A conversation with John Thorp assured me that beacause I had used .032 alclad on the inner wings, I could countersink the added row. I did and no problems after1500 hrs |
| Author: | James Grahn [ Sun Dec 10, 2023 5:05 pm ] |
I recommend a staggered double row. Cubes |
| Author: | James Grahn [ Fri Jan 05, 2024 3:08 pm ] |
And you made the skins wider than plans because you are fitting it on a T fuselage, correct? Cubes |
| Author: | Rv3maker [ Fri Jan 05, 2024 3:25 pm ] |
Hey Cubes, Verified skins are width of S-18 drawing 200 (-1L/-1R). There is one minor difference I see at the outer flap mount bracket cutout. I may have to make a filler piece there - still assessing. Fitting to a S-18 fuselage. Rob |
| Author: | Rv3maker [ Fri Jan 05, 2024 3:28 pm ] |
I could move this thread over to the S-18 wing section. Started here since I was initially discussing the added staggered rivet pattern on the spar caps. |
| Author: | James Grahn [ Sat Jan 06, 2024 2:57 am ] |
Oh. Sorry. I thought you were fitting to a T fuselage. My bad. Cubes |
