| Cutting the 314-4 & 5 outer wing spar cap taper? http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8665 |
| Author: | cw21f [ Sun Jan 02, 2022 10:22 am ] |
| Post subject: | Cutting the 314-4 & 5 outer wing spar cap taper? |
I plan on using a portable metal cutting band saw mounted to a vertical stand to cut or trim my 1/8" thick aluminum angle spar caps to the 1" plan width. My research tells me to use an 8 or 10 TPI bi-metal blade with speed set to ~550 fpm. But elsewhere I am reading that 18 TPI and carbide blade would leave a smoother cut. Any words of band saw cutting wisdom from those you have gone down this path before? Thank you, Chris |
| Author: | fytrplt [ Sun Jan 02, 2022 11:22 am ] |
| Post subject: | Re: Cutting the 314-4 & 5 outer wing spar cap taper? |
I use 14 TPI blade for most everything. |
| Author: | david read [ Sun Jan 02, 2022 8:13 pm ] |
You can cut aluminum on a table saw with a good carbide blade. I didn’t think about it until a friend pointed out that some oak is as hard as aluminum. Back in the day I ripped down my main spar caps that way. Test on a piece of scrap and wear eye protection. |
| Author: | Terry Adams [ Fri Jan 07, 2022 9:20 pm ] |
Check out the metal cutting circular blades that are available. Easiest to use an aluminum cutting circular blade in a table saw. I cut 1/8" steel with a steel blade on a circular saw as easy/fast as cutting a wood 2x4. Very clean cut. |
