It is currently Tue Nov 24, 2026 6:28 pm
rrobut
 Post subject: Wing Profile
PostPosted: Fri Jan 11, 2019 1:41 am
I am a little confused.
The nose rib drawing that came with the S 18 plans shows that the profile is the 63-412 airfoil with dotted lines towards the front indicating that these lines are for the LDS-4-212 airfoil.
However the profile sheet in the plans (for the LDS-4-212) does not seem to match when I try to plot the numbers on the plan drawing.
That is assuming that station 1 on the sheet is the leading edge of the nose rib.
Thanks for the help.
Rob
 Post subject: Re: Wing Profile
PostPosted: Fri Jan 11, 2019 5:03 pm
Is it close enough that the scan could have gotten a little skewed and/or the paper changed size with humidity? I used to see both when I was into RC airplanes.
PostPosted: Sun Jan 13, 2019 7:38 pm
Sorry. I’ve been out of pocket for a bit.
Although I’m not sure I can answer your question anyway. The S18 should be the LDS 4-212 airfoil. The station numbers are in reference to overall station, ie prop flange. Does that help?
rrobut
PostPosted: Mon Jan 14, 2019 6:42 am
Thanks Cubes. My question is answered. At least I know which profile to use
Rob
[ Time : 0.360s | 10 Queries | GZIP : On ]
