It is currently Sun Oct 25, 2026 5:06 pm
 Post subject: Flap return wire
PostPosted: Fri Feb 23, 2018 8:51 am
I was replacing the flap springs last night and noticed the wires (pn 631-2), especially the right one, are getting corroded and pitted. I don’t think I would like to have only one flap deploy so I am thinking it’s time for new. The drawing calls for .09 hard steel wire. Are people using hinge pin to make these?
Thanks
 Post subject: Re: Flap return wire
PostPosted: Fri Feb 23, 2018 10:12 am
Local hobby shop might have what you need.
PostPosted: Fri Feb 23, 2018 10:43 am
I don’t have a local hobby shop unless you count a 2 hour drive as local. I do have about 6 feet of piano hinge with the hinge pin. If I need something else I can call Spruce and have them add it to the order I placed last night.
PostPosted: Fri Feb 23, 2018 11:10 am
The local ACE Hardware carries several sizes of piano wire,maybe try them
PostPosted: Fri Feb 23, 2018 2:32 pm
Try Cubes . Thorp Central probably has them ready made . I got mine from Classic Sport which is now Thorp Central . ;)
PostPosted: Fri Feb 23, 2018 5:23 pm
Thorp Central is a valuable resource to be sure but I have been having some problems matching their stock to a 44 year old hand built aircraft of a different model. In some cases it has been deviations from the drawings in others it has been differences between the models. What I am looking at today is a deviation for sure. I haven’t checked the S-18 drawings yet to see if there is a difference.
TonyNZ
PostPosted: Fri Feb 23, 2018 5:36 pm
Images: 8
A bit of copper coated welding rod 1/8" works well.
Tony Schischka
T18C
ZK-VMS
TonyNZ
PostPosted: Fri Feb 23, 2018 5:38 pm
Images: 8
Ops, I used that as the link between the spring and the flap, not the spring!
Tony
PostPosted: Fri Feb 23, 2018 8:52 pm
I just went ahead and used the hinge pin. It’s fairly strong and there isn’t a lot of pressure on it even when the flaps are full down. If I auger it in with one flap extended then we will know I was wrong.
PostPosted: Fri Feb 23, 2018 9:27 pm
I am always right at least 50% of the time ! :P
PostPosted: Sat Feb 24, 2018 12:33 am
RB does that make you left the rest of the time ???
Phil
118BC
PostPosted: Sat Feb 24, 2018 3:31 pm
I am surprised no one called me out on my comment about only one flap deploying.
PostPosted: Sat Feb 24, 2018 4:09 pm
Nothing gets past me ! You wouldn't be the first T-18 to have split flaps on landing . ??? I can think of one S-18 ( not mine ) that pulled it off . :P
PostPosted: Sat Feb 24, 2018 4:18 pm
I don't think it would happen. I had my right flap stick down after retracting the flaps , on takeoff I would hear a "thump" and it was the flap coming up due to the airflow The airflow over the wing would keep the flaps up. I would think you would be in deep DODO if you had them extended and a cable broken letting one flap retract
PostPosted: Sat Feb 24, 2018 9:36 pm
You could eliminate that connector. I have springs that are unfinished on one end. They are about 14" long. Just bend as desired.
[ Time : 0.222s | 9 Queries | GZIP : On ]
