| LSA S18 wing on Ebay??? http://thorp18.com/thorpforum/viewtopic.php?f=3&t=8081 |
| Author: | BobMoe [ Mon May 01, 2017 6:53 pm ] |
| Post subject: | LSA S18 wing on Ebay??? |
Is this the LSA wing Mike was working on? |
| Author: | James Grahn [ Tue May 02, 2017 2:52 am ] |
| Post subject: | Re: LSA S18 wing on Ebay??? |
I doubt it. He is not computer savvy. I can ask. Do you have a link? Cubes |
| Author: | BobMoe [ Tue May 02, 2017 7:25 am ] |
Look at this on eBay http://www.ebay.com/itm/201912236684 Try this. |
| Author: | James Grahn [ Tue May 02, 2017 6:59 pm ] |
Not sure what that is!? It looks like modified S18 wings to me. Anyone down in Camarillo? Cubes |
| Author: | Rich Brazell [ Tue May 02, 2017 8:20 pm ] |
All that work and not even flush riveted ? RB
| Author: | dan [ Wed May 03, 2017 3:33 pm ] |
Mike didn't go through the process to flush rivet the LSA Bird, as he was trying to make it a slower platform. I believe the outer panels on the LSA were 24" longer than the standard S panels, the fuse was also wider than the S Fuse. I don't know what the wing is in the picture but if you could get the length on the outer wing panels that would probably tell the tail..........Dan |
| Author: | Rich Brazell [ Wed May 03, 2017 4:48 pm ] |
Makes cents for a LSA not to have "flush rivets." Less work . RB
| Author: | James Grahn [ Wed May 03, 2017 9:35 pm ] |
It's not Mikes LSA. Cubes |
| Author: | Rich Brazell [ Wed May 03, 2017 10:33 pm ] |
I may have part of the puzzle ? If you go to the ebay site in the description it sez the wings came with a Pazmany PL-4 donation to the EAA site . It also sez the wings are a "carry thru" in the fus. and it was modified to accept them . If you look at the PL-4 pics you can see the (2) steel wing fittings (S-18 ?) and the "mirror" aileron bell crank . I am NOT a detective , but I played one on TV for one season ! RB
| Author: | bfinney [ Thu May 04, 2017 7:08 pm ] |
I'm with RB on this one, I didn't stay at a Holiday Inn last night but to me it's a Pazmany PL-4 wing modified using the Thorp "C" wing design features to be able to fold the wing. The aspect ratio appears longer than a Thorp C wing outer panel, my guess is that it will only fit the PL-4 fuselage that is also listed on ebay. My 2 cents, your milage may vary. BADA BING, BADA BOOM |
| Author: | Rich Brazell [ Thu May 04, 2017 8:56 pm ] |
I hope the guy bidding on the wing knows this ? They will be in for a big surprise expecting a T-18/S-18 wing when it doesn't fit exactly right ! They should have stayed at the Holiday Inn with Bruce ! RB
| Author: | blueangel59 [ Wed Jul 19, 2017 3:19 pm ] |
It is one of a kind highly modified PL-4 look alike -- Engine is for higher HP not the C-65 and the T-tail is gone, tricycle gear -- use caution for T-18 parts |
| Author: | Rich Brazell [ Wed Jul 19, 2017 5:46 pm ] |
I thought it had been sold according to the ad on Barnstormers ? RB
