Standard T-18 wing aileron bellcrank inspection
http://thorp18.com/thorpforum/viewtopic.php?f=3&t=7974
Author:  Rich Brazell [ Mon Aug 15, 2016 8:37 pm ]
Post subject:  Standard T-18 wing aileron bellcrank inspection
I'll throw this out to the crowd unless someone wants to reopen the fuel feed system associated with the mech and electrical pumps ? No ? OK...here goes . On a standard T-18 wing is it part of your conditional to inspect the aileron bellcranks ? The way I understand it the "standard" wing does not have inspection covers for the cranks ? ??? Does this mean you remove the wing gap cover to inspect ? ::) I have a very good reason for asking this and I'll let you know as soon as I remember what it was ? :o
Shazam
Author:  jrevens [ Mon Aug 15, 2016 11:32 pm ]
Post subject:  Re: Standard T-18 wing aileron bellcrank inspection
That's how I inspect mine, Rich. My big X-ray machine broke.
Author:  Ryan Allen [ Tue Aug 16, 2016 6:54 am ]
That's how I inspect mine too.
Author:  Rich Brazell [ Tue Aug 16, 2016 8:08 am ]
Mucho thanks !
Author:  SHIPCHIEF [ Tue Aug 16, 2016 9:55 am ]
Same here.
Getting some oil into the bellcrank bearing and onto each rod end bearing is a PITA, and I'm not sure if it actually gets there.
I have the wings off right now, so this area is geting a better inspection and / or service before reassembly.
Author:  James Grahn [ Tue Aug 16, 2016 10:15 am ]
Same with me. I wish I had covers there.
Author:  Ryan Allen [ Tue Aug 16, 2016 8:28 pm ]
SHIPCHIEF wrote:
Same here.
that's my concern too.
Author:  Rich Brazell [ Tue Aug 16, 2016 8:52 pm ]
Well I'll add my 2 cents worth regarding these little devils . I am helping a good friend with his conditional and I got the wing gap covers off today and can see the problem with the bell crank access . As I have the S-18 I am fortunate to have access covers to the cranks . I came up with a solution for my AC when it comes to lubing hard to reach areas and it is quick , easy and cheap ! It involves using the plastic straw that comes with almost every spray can of lube and a length of K & S metal tubing (you can get this tubing from most hobby and local hardware stores) . Cut the plastic straw in half and insert it into the K & S tubing (it comes in brass, aluminum and I think steel) . I went with the aluminum tube . You can either silicone around the insert area or slightly crimp the tube and straw . This set up will give you extended range and control over the lube . You can also slightly bend the aluminum tube if necessary . The lube will not spray out , it has a steady drip/flow . With the hidden portion of the bell crank I think I can use an inspection mirror and light to direct the metal tube to where I want the lube to go . Probably would work even better with 2 knuckleheads conducting this precision maneuver ? :o
Adding an access cover in this area for the "Standard" T-18 wing would be a good option during the building process . ???
As an added bonus after lubing you can use the tube to fill cannoli , fill party balloons and possibly do those long over due medical procedures ! :P
Shazam
Author:  david read [ Wed Aug 17, 2016 8:45 pm ]
Wicks sells an extremely flexible plastic hose that is designed to fit into the spray nozzle about 3 feet long. It is great for reaching into those hard spots. I saw them in their booth at OSH this year, they are cheap as I recall.
