| AN bolts http://thorp18.com/thorpforum/viewtopic.php?f=3&t=7709 |
| Author: | Robb777 [ Sat Jan 17, 2015 11:28 am ] |
| Post subject: | AN bolts |
I am replacing the pins in my folding wing with AN bolts. For those who have done this already. How were you able to gain access to torque the nuts? There isn't much room once the wing is in place. Any suggestions would be greatly appreciated. Rob |
| Author: | fytrplt [ Sat Jan 17, 2015 12:09 pm ] |
| Post subject: | Re: AN bolts |
I built my access cover a little longer so I could get to the back side with a box wrench. Torque as required from the tables for this size bolt is way too much. I use thin self locking nuts. Turn the nut and not the bolt as you will gall the bolt/holes if you turn the bolt in the holes. Where did you obtain the bolts; others would like to know. |
| Author: | Rich Brazell [ Sun Jan 18, 2015 10:24 pm ] |
When it come to AN bolts , I generally order a few extra for spares and should the bolt hole be a close tolerance hole I can try 1 or 2 other bolts to try and improve the fit . The bolts can vary slightly in size . BADA BING , BADA BOOM ! RB |
| Author: | Robb777 [ Thu Feb 05, 2015 3:33 pm ] |
I ordered mine through Spencers in Washington |
| Author: | Rich Brazell [ Sat Feb 07, 2015 12:34 am ] |
Another source that I have used that carries that "odd" sizes is http://www.gen-aircraft-hardware.com located in Paso Robles, CA . BOOM !RB |
