| Center Wing Hi Shear Installation in upper spar cap channel http://thorp18.com/thorpforum/viewtopic.php?f=3&t=7599 |
| Author: | jubal_sackett [ Sun Jun 29, 2014 4:47 pm ] |
| Post subject: | Center Wing Hi Shear Installation in upper spar cap channel |
What is a good technique for driving the hi shear rivets used to attach the wing attach brackets and control bracketry to the main beam? Is there an offset rivet set available to get up under the channel or do I need to make one or ? Tom |
| Author: | leewwalton [ Sun Jun 29, 2014 5:01 pm ] |
| Post subject: | Re: Center Wing Hi Shear Installation in upper spar cap chan |
Use an AN3 bolt instead. |
| Author: | jubal_sackett [ Sun Jun 29, 2014 7:26 pm ] |
Thanks Lee, I may not have been very clear on my question. I am looking at the 556 walking beam mounting bracket and the 522 wing attach fitting on center wing section main beam for attaching wing to fuselage shown with countersunk hi shears to avoid interference at the fuselage bulkhead interface to wing. If there is a substitute for the countersunk hi shears that would be good; otherwise, I am somewhat perplexed as how to set the hi shears in the U channel portion of the center section upper spar cap and was hoping not to re-invent the wheel. Tom |
| Author: | leewwalton [ Sun Jun 29, 2014 7:34 pm ] |
Sorry, I understand now. Use countersunk 10/32 ms screws. |
| Author: | leewwalton [ Sun Jun 29, 2014 7:36 pm ] |
Use proper grip/length, but ms screws/an bolts and high shears are interchangeable. |
| Author: | jubal_sackett [ Sun Jun 29, 2014 9:48 pm ] |
Ah... I had not made the connection between ms screws and an bolts. Screws will definitely simplify the concept. Thanks |
| Author: | Bill Williams [ Sun Jul 20, 2014 3:46 pm ] |
Previous builders substituted AN hardware in lieu of Hi-Shears through out the wing. |
| Author: | alphaone [ Sun Jul 20, 2014 5:45 pm ] |
Thanks I have access to AN bolts, but high sheer rivits are harder to come by... plus I have nothing to set them. |
| Author: | James Grahn [ Sun Jul 20, 2014 7:32 pm ] |
You can use regular rivets to attach wing ribs to the spar. Is that where you are talking about? Just make sure they are not dash 0. Cubes |
| Author: | James Grahn [ Sun Jul 20, 2014 7:33 pm ] |
Disregard last. I figured out where you were talking about. Cubes |
