| Push pull tube http://thorp18.com/thorpforum/viewtopic.php?f=3&t=6823 |
| Author: | BobMoe [ Tue Oct 18, 2011 1:15 pm ] |
| Post subject: | Push pull tube |
I have a set of push pull tubes with the ends Swagged/narrowed/reduced to 1/2" and I was wondering how this is done. |
| Author: | Stephen Peirce [ Tue Oct 18, 2011 1:51 pm ] |
Tube swage process is done mostly with aluminum, copper or thin wall steel. Can be accomplished on a tube or a solid rod and reduce the outside diameter down to a specific diameter using a die. Cold tube swaging is relatively quick, inexpensive and chipless. |
