| which AN bolt for wing? http://thorp18.com/thorpforum/viewtopic.php?f=3&t=6441 |
| Author: | dcuke [ Thu Dec 16, 2010 7:33 pm ] |
| Post subject: | which AN bolt for wing? |
I am starring at the 599 and I am trying to figure out what AN bolt,nut,washer to get for mounting the wing to the fuselage. I see only the the specs for the AVDEL BALL-LOK PIN, but no specs for which bolt to use. I see an 5-4A on the drawings, but that is way to short to put through the wing/fuselage... besides that, I cannot find any other reference to a bolt. Am I crazy or is it not shown? Can anyone let me know which bolt to use? |
| Author: | Jim Mantyla [ Thu Dec 16, 2010 8:58 pm ] |
dcuke, Why don't you just add up the thicknesses of the materials that make up the spar , add the thickness for a couple of washers and look it up on the AN/MS bolt chart? Jim Mantyla |
| Author: | leewwalton [ Fri Dec 17, 2010 12:43 am ] |
Dean, have a look here http://thorp18.com/forum/topic.asp?ARCH ... IC_ID=5695 If it's the main bolts I think it's an AN6-25 |
| Author: | dcuke [ Fri Dec 17, 2010 10:49 am ] |
Great. Thanks. it looks like the main bolt is AN6-25. nut - 365-624a. washers - 960-6 |
| Author: | Rich Brazell [ Fri Dec 17, 2010 11:06 am ] |
Looking thru my parts catalog, it appears I ordered an AN6-22A bolt. RB |
| Author: | dcuke [ Tue Feb 01, 2011 10:47 am ] |
an6-22a is the correct bolt. 6-25a is just a little too long |
| Author: | Fla-T18 [ Sun Apr 29, 2012 11:24 am ] |
| Post subject: | Re: which AN bolt for wing? |
Thanks for this post, I was going to ask about the very thing. I will be ordering the bolts. |
| Author: | stug [ Tue May 01, 2012 7:07 am ] |
It you were interested in the Ball-loc pins they are still available from Avibank. The Australian distributor quoted me $42.39AUD each on the basis of a minimum order of 11. Thats for the BL S 6 TA 17 S that is called for in the plans. That is one expensive bolt and also requires a 6-9 week lead time on manufacture. |
