It is currently Sun Oct 25, 2026 8:41 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
rhartmaier
 Post subject: Re: Flap construction
PostPosted: Sat May 20, 2017 7:54 am
It just occurred to me that if I use .020 for the skins, and .050 for the strip, I get the same dimension as the aileron T.E. I did not realize what a genius I am!
PostPosted: Sat May 20, 2017 12:26 pm
It wasn't early, it was 9:30 PM local (west coast).
The flaps are spring loaded up so they could potentially flutter given the right conditions (not enough spring tension for one). Any movable surface has the potential to flutter.
rhartmaier
PostPosted: Sat May 20, 2017 6:56 pm
Thanks for the comment. Good point.....
PostPosted: Sat May 20, 2017 10:56 pm
.020 skins are fine. .016 is still available but extremely hard to work with. Please use the correct trailing edge strip size.
rhartmaier
PostPosted: Mon May 22, 2017 7:35 am
Cubes,
Thanks for the advice. I will go to the airport and cut two .040 T.E. strips today.
Bob
[ Time : 0.217s | 10 Queries | GZIP : On ]
