It is currently Wed Sep 30, 2026 9:15 am
 Post subject: Re: Flap indicator
PostPosted: Sat Mar 16, 2013 10:49 pm
Sitting in the cockpit, I'm not remotely close to getting gouged by the fap handle bracket. I have simmered the thought of elec flaps but I am like Rich, it would be a project to get it done.....Dan
PostPosted: Mon Mar 18, 2013 6:43 am
I am working towards a solution with a built in flap position indicator.
I plan to use the Firgelli FA-PO-150-12-2 which has in built position feedback and combine it with an e flap controller.
http://www.seareycanada.com/Welcome%20to%20eFlaps.pdf
The ACI e flap controller is both the switch and the indicator, it will drive the flaps to a pre set position with a single press of the relevant button, the button lights to indicate which stage of flap is set. Probably not to everyone's taste but I think it strikes a good balance.
By my estimate electric flaps work out at about 1.2 pounds heavier than the flap handle and that seems like a reasonable trade for cleaning up the centre tunnel and improving cabin comfort.
I thought from reading past news letters the recommended flap extension speed was 100mph although I have seen some T18 operators manuals where the max speed was 110.
Stug
PostPosted: Tue Mar 19, 2013 10:18 pm
stevehawley wrote:
I'm curious, what speed do some of you use for lowering the flaps. I've been using 120mph for years but does anyone use a higher one. Did John ever say what the max is?
Steve Hawley
100 mph is the design flap extension speed.
[ Time : 0.164s | 12 Queries | GZIP : On ]
