It is currently Tue Sep 29, 2026 3:32 pm
t18joe
 Post subject: Wheel Camber
PostPosted: Tue Sep 14, 2021 10:56 pm
I have been going thru tires in about 80 hours. Checked the camber = -87.7 deg. I removed the tire and the axle. The gear strut flange angle was about the same. Thinking a shim would work, I made a 2 deg shim. Tried to install the shim, the shim angle was so large the axle holes and the holes in the strut flange were offset. see attachment.
Any ideas would be greatly appreciated
 Post subject: Re: Wheel Camber
PostPosted: Tue Sep 14, 2021 11:15 pm
Have you tried just a washer?
PostPosted: Wed Sep 15, 2021 1:52 am
Have you check toe alignment? Camber won’t have a big effect on tire wear. Toe in or out will eat them up pretty quick if excessive and make ground handling much more darty/twitchy.
pmandel
PostPosted: Sun Sep 19, 2021 9:43 am
Per prior discussion of wheel alignment in this forum, I used a slice of a Coke can as a shim. Worked like a charm, although for me it was a toe-out issue that needed fixin'.
Philip Mandel
N118BC
S/N 957
Beaverton OR
t18joe
PostPosted: Tue Sep 28, 2021 11:58 pm
Thanks for your inputs. I measured the camber = -2 deg. This tire has 80 hrs (see pic).The A/C has no adverse characteristics during T/O, landing rollout or taxi. I am not comfortable with the bending loads on the bolts (see pic). My approach is, mill a 2 deg taper into a new axle hub face. offset the axle stub holes .025" and spotface (2 deg) the outer bolt hole surface of the axle stub face. My experience in A/C structural testing may promote my overkill outlook. Will advise on the results. I appreciate your inputs
Camber Shim.pptx [40.67 KiB]
Downloaded 1308 times
PostPosted: Wed Sep 29, 2021 12:09 am
Wow! That’s a LOT of wear. Are you certain the gear are not bent?
PostPosted: Wed Sep 29, 2021 12:37 am
Did you check the toe yet? Almost guarantee that’s tow out wear, not camber. Would suck for you to spend all that time on camber and wind up in the same boat! I had a Sonerai with somewhat weak spring gear. The camber was always negative. Didn’t affect wear much at all. Off camber doesn’t wear tires much.....toe does!
[ Time : 0.213s | 14 Queries | GZIP : On ]
