It is currently Mon Oct 26, 2026 1:48 am
PostPosted: Fri May 10, 2019 1:43 pm
Unclerap
PostPosted: Fri May 10, 2019 5:05 pm
Rap
Base: KALX
N8786
SN 929
PostPosted: Fri May 10, 2019 6:31 pm
PostPosted: Fri May 10, 2019 8:30 pm
PostPosted: Fri May 10, 2019 9:44 pm
PostPosted: Fri May 10, 2019 11:49 pm
PostPosted: Sat May 11, 2019 7:53 am
DrDrift
PostPosted: Sun May 12, 2019 1:49 am
D = q * S * Cd
Using metric units (sorry):
V = 82 m/s (160kts)
Rho = 1.225 kg /m^3
S = 0.004 m^2 (6 in^2)
Cd = 1.3
Calculating...
D = 21 Newtons or 4.8 pounds.
As a side curiosity...
PostPosted: Sun May 12, 2019 8:52 am
PostPosted: Sun May 12, 2019 11:16 am
PostPosted: Sun May 12, 2019 1:19 pm
PostPosted: Sun May 12, 2019 4:57 pm
Just a data point.
DrDrift
PostPosted: Sun May 12, 2019 7:13 pm
Fraser,
PostPosted: Tue May 14, 2019 7:25 pm
PostPosted: Sat May 18, 2019 6:37 pm
[ Time : 0.284s | 14 Queries | GZIP : On ]
