Force of wind on a landing light
http://thorp18.com/thorpforum/viewtopic.php?f=29&t=8368
Page 1 of 2
Author:  Ryan Allen [ Fri May 10, 2019 1:43 pm ]
Post subject:  Force of wind on a landing light
Author:  Unclerap [ Fri May 10, 2019 5:05 pm ]
Post subject:  Re: Force of wind on a landing light
Rap
Author:  leewwalton [ Fri May 10, 2019 6:31 pm ]
Author:  Rich Brazell [ Fri May 10, 2019 8:30 pm ]
Author:  James Grahn [ Fri May 10, 2019 9:44 pm ]
Author:  Fraser MacPhee [ Fri May 10, 2019 11:49 pm ]
Author:  Ryan Allen [ Sat May 11, 2019 7:53 am ]
Author:  DrDrift [ Sun May 12, 2019 1:49 am ]
D = q * S * Cd
Using metric units (sorry):
V = 82 m/s (160kts)
Rho = 1.225 kg /m^3
S = 0.004 m^2 (6 in^2)
Cd = 1.3
Calculating...
D = 21 Newtons or 4.8 pounds.
As a side curiosity...
Author:  James Grahn [ Sun May 12, 2019 8:52 am ]
Author:  Fraser MacPhee [ Sun May 12, 2019 11:16 am ]
Author:  fytrplt [ Sun May 12, 2019 1:19 pm ]
Author:  James Grahn [ Sun May 12, 2019 4:57 pm ]
Just a data point.
Author:  DrDrift [ Sun May 12, 2019 7:13 pm ]
Fraser,
Author:  Rich Brazell [ Tue May 14, 2019 7:25 pm ]
Author:  Fraser MacPhee [ Sat May 18, 2019 6:37 pm ]
