| Corrosion Control http://thorp18.com/thorpforum/viewtopic.php?f=29&t=8135 |
| Author: | fytrplt [ Sat Aug 19, 2017 12:28 pm ] |
| Post subject: | Corrosion Control |
I've got my instrument panel out for ADSB update. Found some corrosion on dash and other basic fuselage parts . Question is: ACF-50 or Corrosionx? |
| Author: | 1albee [ Sun Aug 20, 2017 7:10 am ] |
| Post subject: | Re: Corrosion Control |
Corrosion X is thicker viscosity that stays in place longer. ACF - 50 is much thinner viscosity and creeps more into lap seems but does not last as long, if you use it as recommended you may find it coming out of seems / joints for a while. Phil 118BC |
| Author: | Rich Brazell [ Sun Aug 20, 2017 11:29 am ] |
I like stuff getting into my cracks and crevices ! I would prefer corrosion treatment to get between the sheets as much as possible . It's the stuff you can't see that leads to bigger problems .RB
| Author: | Rich Brazell [ Fri Aug 25, 2017 9:43 pm ] |
August Sport Aviation has a good article on corrosion control and what to apply . RB
