| Oil dipstick tube http://thorp18.com/thorpforum/viewtopic.php?f=29&t=6320 |
| Author: | Ryan Allen [ Thu Oct 07, 2010 1:27 pm ] |
| Post subject: | Oil dipstick tube |
Pretty sure thats not the proper terminology, but the "stem" that that oil dipstick screws into....which is attached to the block...thats what I'm talking about. Well, where the "stem" that sticks down in the block is loose. I can just pull it out with my hands. Its blowing oil out from this joint. What is the appropriate method to secure this stem to the block? |
| Author: | lance38dt [ Thu Oct 07, 2010 2:05 pm ] |
Mine was loose some time ago and some oil was blowing out, but I could not get it out, consulted a few A&P friends and they couldnt help.I finally cleaned it well and used some JB weld at the bottom it`s been fine since. |
| Author: | fytrplt [ Thu Oct 07, 2010 2:08 pm ] |
It screws in. Many of them are made of plastic. Sounds like you need a new one. They are supposed to be safetied so they can't get loose. The paper gasket at the base has been known to wear out and let the filler tube wobble. Enough wobbling and the tube will wear out the threads. I have modified mine to use an "O" ring there. |
| Author: | Ryan Allen [ Thu Oct 07, 2010 3:09 pm ] |
I thought they screwed in myself but this one is as smooth as a baby's behind on both the tube and the case. I'll try the o ring and see what happens. |
| Author: | Rich Brazell [ Thu Oct 07, 2010 4:14 pm ] |
Have you checked the block ? Any threads in there ? Something doesn't sound right. Should screw in with a gasket and have a safety wire hole in the base of the tube and a hole on the block to safety wire it all up. [;)] I guess you said it was smooth on the block. Still doesn't sound right. It would have to be "pressed in" if this is the case. What engine is it ? RB |
| Author: | Bill Williams [ Thu Oct 07, 2010 5:11 pm ] |
You have a 0-290 GPU? I think they are a pressed fit or someone glued it in and all you see is a smooth surface. |
| Author: | Ryan Allen [ Thu Oct 07, 2010 5:38 pm ] |
Yep, I have an 0-290 and its absolutely smooth...both block and stem. Theres no glue or any substance on either the block or stem. Both are completetly clean and smooth. Maybe I should just use some JB weld as descibed above. |
| Author: | Victor Thompson [ Thu Oct 07, 2010 5:43 pm ] |
Not sure your engine particulars, however this service bulletin discuss oil filler tube. It may shed some light on your problem. http://www.lycoming.textron.com/support ... SB545A.pdf http://www.lycoming.textron.com/support ... index.html |
| Author: | Ryan Allen [ Thu Oct 07, 2010 7:44 pm ] |
Thanks Victor. I may try and snap a picture of my setup tomorrow and post it to see what everyone thinks about it. |
| Author: | Rich Brazell [ Thu Oct 07, 2010 7:52 pm ] |
I would think a properly fitted tube may be in order (assuming it is a press fit), rather than "gluing in" the old loose one. If that is the case, there must be a way it is secured to the crank case...safety wire/clamp or ? Using an epoxy to secure the tube may at best be temporary (high heat/vibration area). There must be a manual describing the install for this tube. If the tube were to work loose in flight the loss of oil would be Muey Pronto ! [:0] RB |
| Author: | lance38dt [ Fri Oct 08, 2010 5:19 am ] |
Before I used JB weld on my 0290 I tried all the above, no threads ,not plastic ,no hole for safety wire. |
| Author: | Ryan Allen [ Fri Oct 08, 2010 6:19 am ] |
Lance, mine is the same as yours. Slick everywhere, no safety wire attach point or anything. Rich, I agree with you, but even if I get a new one resulting in a much tighter fit/tolerance, I believe it would rattle loose again over time without something to hold it other than friction. I have the 0-290 conversion book and it shows threads! |
| Author: | Rich Brazell [ Fri Oct 08, 2010 9:54 am ] |
Isn't that a pisser ! [:o)] Maybe a call to Lycoming to get the skinny on this tube ? Your's can't be the only one to have done this and what is the "real fix." [?] If you did epoxy it in, I would look for some way to bracket/clamp it to the block. Some sort of stand off with a clamp ? RB |
