It is currently Sat Nov 07, 2026 11:18 am
gkerr
 Post subject: High CHT
PostPosted: Sun Oct 31, 2010 8:03 am
In my O-320 the rear aft cylinder, #4, runs hotter by about 50 plus degrees than the rest of them. It is always in the high green in cruise (385 if I'm lucky) and in a climb at full power I'm banging against the yellow (435). Compression's OK (70/80), can't hear any valve blow-by. I've improved the baffling and can't see anything wrong with it, I can't find any obvious induction leaks and finally, the ignition timing is dead on. In flight I occasionally get an almost undetectable roughness. It's really baffling (how about that for a pun) me!
Any ideas?
Graham Kerr (N444DD)
PostPosted: Sun Oct 31, 2010 9:28 am
I guess we can assume you have swapped leads with another cylinder and ruled out a sensor issue. Also, do the plugs indicate a lean situation in that jug? As my engine guy is quick to say, "Each cylinder is its own science project".
PostPosted: Sun Oct 31, 2010 10:40 am
You said you improved the baffling. How is the clearance between the rear of the cylinder fins and the baffle ? Some cylinders have a problem with the casting between the fins, creating an air flow problem. If this is the case a "spacer" may be in order to increase the clearance between the back of the fins and the baffle. Picked this little tidbit up on the Vans site.
PostPosted: Sun Oct 31, 2010 11:52 am
My number 4 used to run real hot (pre-rebuild). One day while looking at the baffles I noticed something odd about the back side of the number 4. I reached in there and pulled out a roll of electrical tape (looked about as old as the airplane) that had fallen behind the cyl and became lodged back there. Once I pulled it out it ran nice and cool. The roll of tape effectively reduced the clearance back there as Rich pointed out. It makes a big difference!
admin
PostPosted: Sun Oct 31, 2010 12:00 pm
Rich,
The rear baffle actually is against the cooling fins. I'll try the spacer and report back to the group.
GK
*** admin posted for Graham Kerr ***
Forum Administrator
PostPosted: Sun Oct 31, 2010 1:54 pm
I doesn't need much clearance...1/8" to 1/4" I can't recall how the RV guys put in the spacer ? Seems a "thick" washer pop riveted between the fins and the baffle should work. Or a short piece of square alum. stock attached to the baffle to push it away from the cyl. fins. [;)]
admin
PostPosted: Mon Nov 01, 2010 9:15 am
These are some pics sent via Rich Brazell from the Vans site. Gary Green did a writeup a short while back on this very same subject regarding installing the Vans Baffle set and clearance behind the #4 cyl. If I can round it up, I'll post a copy here.
Forum Administrator
admin
PostPosted: Mon Nov 01, 2010 10:33 am
While mine is apart for paint, I'll be working on cleaning up the cowl,
baffling and exhaust exit points. We'll have to wait for spring to see the
outcome!
Chuck
*** admin posted for Chuck K ***
Forum Administrator
[ Time : 0.214s | 10 Queries | GZIP : On ]
