It is currently Sat Nov 07, 2026 11:30 am
Fredl
 Post subject: Hydraulic brakes
PostPosted: Tue Apr 23, 2013 5:30 pm
I just converted over to hand brakes(2) and I can not get he left brake to et hard. Any suggestions
I can get it pumped up but it won't stay pumped up.
 Post subject: Re: Hydraulic brakes
PostPosted: Tue Apr 23, 2013 7:27 pm
Hand brake ? Hummm ? Hand pump leaking ? As with any hydraulic system it has to be air in the system or a bad master cylinder ( O-rings) or a bad wheel cylinder (O rings) . A loose fitting may allow air to enter the system ? I would look first at the wheel caliper to see it there is any fluid leaking there . A first for me , never heard of a Thorp with "hand brakes ?" Lee would have the scoup on this ?
PostPosted: Tue Apr 23, 2013 10:20 pm
You got me RB!
PostPosted: Tue Apr 23, 2013 10:58 pm
Maybe pics of the hand pump system would clear this up ? ??? It might help explain the lack of pressure in the one side ? ;) Low PSI BOOM !
[ Time : 0.217s | 9 Queries | GZIP : On ]
