It is currently Wed Oct 14, 2026 3:59 am
PostPosted: Wed Nov 13, 2019 1:27 pm
Cubes asked that I post this for all Constant Speed operators ...
NYCO Introduction Letter.pdf [385.21 KiB]
Downloaded 3032 times
PostPosted: Mon Dec 02, 2019 6:02 pm
Due diligence. I forwarded this letter to an FBO on my field. The IA asked if it would be ok to pull one zerk fitting and pump this new grease through. Here’s the answer from Hartzell.
This new grease will ONLY be installed at a teardown. DO NOT mix this with the Aeroshell 6 that is currently in your prop!! They are not compatible. As you might have read, Hartzell will be using this in all new props after the first of the year.
[ Time : 0.301s | 11 Queries | GZIP : On ]
