It is currently Mon Nov 02, 2026 1:26 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Owner Pin Map
PostPosted: Fri Jul 10, 2020 12:41 pm
Lee,
What is the easiest way to update the Thorp Dot Net pin map?
 Post subject: Re: Owner Pin Map
PostPosted: Fri Jul 10, 2020 12:46 pm
I do that .. in a nut shell I take the Thorps in the FAA and registry pull the addresses down, update the list with known changes, geocode the list then feed them to Google Maps. It is very much out of date right now.
PostPosted: Fri Jul 10, 2020 2:21 pm
Thanks, Lee. In the meantime, guys and gals, check out the pin map on the web site. You might find a Thorp in your neighborhood!
PostPosted: Sat Jul 11, 2020 8:46 am
Lee, if you want location info for the T18’s in Canada, I can dig it up.
We have 15 or 16 active airplanes here.
Also, if you need a Canadian Thorp Ambassador, I’m happy to throw my hat in the ring.
Dick Wolff
C-GABY
CYKM
PostPosted: Sat Jul 11, 2020 9:39 am
Thanks Dick!
speedbird1
PostPosted: Sat Jul 11, 2020 12:41 pm
OK Guys,
Enlighten my darkness and tell me how/where I can find this "Owners Pin Map??
Speedbird 1.
N872DD
200hp Lycoming
PostPosted: Sat Jul 11, 2020 1:14 pm
Click on the Thorp logo in the upper right corner of this page and then click on "Thorp Map".
speedbird1
PostPosted: Sun Jul 12, 2020 3:45 pm
Thanks Bob,
Another of the sites secrets found.
Lee, you can add N972DD to Helena, Montana when you get around to it.
Speedbird 1.
N872DD
200hp Lycoming
PostPosted: Fri Jul 17, 2020 6:57 pm
The Thorp Map has been updated with the latest FAA Registry data.
PostPosted: Fri Jul 17, 2020 7:27 pm
Thanks, Lee.
fulcrumflyer
PostPosted: Fri Jul 17, 2020 11:00 pm
It dropped me and I still have my Thorp. So much for the FAA registry. But why would one trust the guvmint anyway?
Spanky
PostPosted: Sat Jul 18, 2020 10:01 am
I had forgotten how much info is on the home page. I can’t access much of it with my iPhone. Using iPad this morning and appear to have access to all of it. Kinda weird since the two use the same iOS and browser.
PostPosted: Sat Jul 18, 2020 10:16 pm
I’m working on the mobile version. ... noticed that today as well.
JDUB
PostPosted: Sun Jul 19, 2020 9:58 pm
LEE, PLEASE PIN N38DT IN JACKSONVILLE, FLORIDA
THANKS JERRY LANKFORD
speedbird1
PostPosted: Mon Jul 20, 2020 9:36 am
Lee,
Please add N872DD as being alive and well in Helena, Montana. Actually alive and getting better as I go through it after delivery from Florida.
Speedbird 1.
N872DD
200hp Lycoming
[ Time : 0.171s | 9 Queries | GZIP : On ]
