Spinner Back Plate
http://thorp18.com/thorpforum/viewtopic.php?f=25&t=7042
Author:  Fraser MacPhee [ Tue Jun 19, 2012 5:24 pm ]
Post subject:  Spinner Back Plate
Does anyone out there have a backing plate for a Thorp spinner and for a C/S Prop? - I have a Brock spinner that needs a little TLC - am not sure whether it is drilled for standard holes, but have access to a good AL welder to fill in the holes on the spinner if the need arises. The current backing plate has been drilled out twice and I should probably get a new one, rather than risk it's failure down the road.
Author:  Rich Brazell [ Tue Jun 19, 2012 11:56 pm ]
Post subject:  Re: Spinner Back Plate
?QUE Paso ? What size Senior ? ??? I think you can get an "undrilled buckhead" from Spruce ? A new plate might be cheaper and "safer" than a welded up disc ? ;)
Author:  leewwalton [ Wed Jun 20, 2012 6:31 am ]
Won't work RB he needs a cs backplate specific to the Thorp. A totally different breed from what is available from ACS.
One other option for you Frase is the PA-30 or PA-23-250 spinner/backplate combo. That works on the Thorp too.
Author:  Fraser MacPhee [ Tue Jul 03, 2012 9:14 pm ]
Floo up to Ogden last Friday to check out a composite company that makes spinners and back plates for all makes and models of aircraft - Nice young man said they would happily make one for the T-18.
It was a short visit - the guy tried to sell me a different 13.5 inch spinner on the spot - a lot of talking - not enuff listenin - he quoted about 800 for the mold and a "few hundred" for a spinner and "I don't know, but we'll figger out sumpinout" about the back plate.
Later that day, I ordered a spinner and back plate from Mike Archer and will have it in a cupla weeks.
Author:  Fraser MacPhee [ Sun Oct 14, 2012 5:03 pm ]
New Walton Aviation spinner installed - a few photos below - templated Homey's prop bake opeings and shrunk it a little bit as my prop has less blade cord - the cut out using a thin cutoff blade, riveted a doubler and installed behind the prop - the nose tracks dead nuts - the back plate looks like it has a little wobble in it, but I think it's because of the slight warpage between screws, the spinner being carbon fiber - gonna wallow out the holes just a sniglet and let it settle in. Nice tight fit with no rubbage on the prop blades - I think the spinner added 3 MPH.
Disclaimer - had alot of help from hangar neighbor, who has every tool necessary to build a boeing 787, but the desired result I am happy with.
Author:  Rich Brazell [ Sun Oct 14, 2012 6:12 pm ]
Pretty nice job for a cross dresser ! :-* Always good to have a buddy with all the tools you don't have ! ;)
Author:  leewwalton [ Sun Oct 14, 2012 6:37 pm ]
That's what I'm talkin a about! Looks great Frase! May it give you many years of fatigue free service!
Author:  jrevens [ Sun Oct 14, 2012 10:42 pm ]
It Looks very good Frase!
Author:  mattst18 [ Mon Oct 15, 2012 5:10 pm ]
Hi Fraser,
What did you use for a front bulkhead?
Author:  leewwalton [ Mon Oct 15, 2012 6:26 pm ]
Matt,
I copied Bob Highley's front bulkhead design. Fraser has a CS prop so it's not going to apply to a fixed pitch prop. Basically it's a formed aluminum ring bonded onto the spinner with an again formed kydex ring for anti-chafe against the prop hub.
Here's a pic ...
Author:  dickwolff [ Tue Oct 16, 2012 5:53 am ]
With a little creativity and ingenuity, I think this method of making a "floating" front bulkhead could be made to work with a fixed pitch prop. I have been thinking of having the front bulkhead float on tube that is perfectly centered by the center hole in the prop hub. Same idea as Bob's, just a smaller hole/ring in the disk.
The builder of Tim Brown's Thorp did something similar.
http://thorp18.com/forum/images/postedi ... C00225.JPG
d
