| Inverter for WW II compass http://thorp18.com/thorpforum/viewtopic.php?f=22&t=6459 |
| Author: | Rich Brazell [ Fri Dec 31, 2010 10:34 am ] |
| Post subject: | Inverter for WW II compass |
The inverter ( if it has one ) would probably be mounted away from the remotely located head to reduce/eliminate interference. Most large A/C I flew had a slaved/remote compass system and placed the head near the wing tip. If you find it, removing both units and the wiring will probably reduce your weight by about 6-8 pounds. [;)] RB |
