528 Fuel Tank Support
http://thorp18.com/thorpforum/viewtopic.php?f=2&t=8638
Author:  jubal_sackett [ Sat Sep 11, 2021 5:44 pm ]
Post subject:  528 Fuel Tank Support
I am preparing to start fab on T18 Fuel Tank Supports and found the attached diagram with a mod for pedal interference in the newsletter archive. Before getting too far into the fab thought I should ask if a consensus was developed on how to deal with the interference? I am using A-528R as my reference.
File comment: Fuel Tank Support Diagram
Fuel tank support.pdf [112.22 KiB]
Downloaded 1257 times
Author:  fytrplt [ Sun Sep 12, 2021 1:20 am ]
Post subject:  Re: 528 Fuel Tank Support
I did not find that I needed to make the mod. I also have the removable floor, so checking the fit and later modifications would be easier.
Author:  jubal_sackett [ Sun Sep 12, 2021 12:46 pm ]
I expect the removable floor has many benefits. I will put on my list. Since you didn't need the mod, is the interference more of a potential mechanical tolerance build up or is it a shoe size issue?
Tom
Author:  fytrplt [ Sun Sep 12, 2021 3:37 pm ]
I think it assumes a fully compressed master cylinder, something that shouldn't happen. The length of your rudder cables can influence rudder pedal travel.
Author:  jubal_sackett [ Sun Sep 12, 2021 4:00 pm ]
Thanks for the insight, Bob
Tom
Author:  Ryan Allen [ Sun Sep 12, 2021 6:24 pm ]
For whatever its worth, neither my flying plane nor my project have the rudder pedal/tank support interference issue.
Author:  jubal_sackett [ Mon Sep 13, 2021 12:50 pm ]
Thanks for the data point Ryan.
Tom
