It is currently Sat Oct 31, 2026 7:35 am
jubal_sackett
 Post subject: 528 Fuel Tank Support
PostPosted: Sat Sep 11, 2021 5:44 pm
I am preparing to start fab on T18 Fuel Tank Supports and found the attached diagram with a mod for pedal interference in the newsletter archive. Before getting too far into the fab thought I should ask if a consensus was developed on how to deal with the interference? I am using A-528R as my reference.
File comment: Fuel Tank Support Diagram
Fuel tank support.pdf [112.22 KiB]
Downloaded 1256 times
PostPosted: Sun Sep 12, 2021 1:20 am
I did not find that I needed to make the mod. I also have the removable floor, so checking the fit and later modifications would be easier.
jubal_sackett
PostPosted: Sun Sep 12, 2021 12:46 pm
I expect the removable floor has many benefits. I will put on my list. Since you didn't need the mod, is the interference more of a potential mechanical tolerance build up or is it a shoe size issue?
Thanks
Tom
PostPosted: Sun Sep 12, 2021 3:37 pm
I think it assumes a fully compressed master cylinder, something that shouldn't happen. The length of your rudder cables can influence rudder pedal travel.
jubal_sackett
PostPosted: Sun Sep 12, 2021 4:00 pm
Thanks for the insight, Bob
Tom
PostPosted: Sun Sep 12, 2021 6:24 pm
For whatever its worth, neither my flying plane nor my project have the rudder pedal/tank support interference issue.
jubal_sackett
PostPosted: Mon Sep 13, 2021 12:50 pm
Thanks for the data point Ryan.
Tom
[ Time : 0.196s | 10 Queries | GZIP : On ]
