| Anchoring the Instrument Panel http://thorp18.com/thorpforum/viewtopic.php?f=2&t=8132 |
| Author: | Ryan Allen [ Wed Aug 16, 2017 11:28 am ] |
| Post subject: | Re: Anchoring the Instrument Panel |
how about a plate nut on the backside of the bulkhead? Then use a long AN3 bolt through the panel and screwed into the platenut. Slide a piece of AL tubing on the bolt shaft in between the panel and bulkhead. You could even go so far as put a big washer on each end of the tubing where it touches the panel and the bulkhead. |
| Author: | James Grahn [ Wed Aug 16, 2017 12:14 pm ] |
Make a "flag" from a piece of metal tube and a 1 by 2 inch flat stock. Bolt the flag to the lower left and right corners so you end up with a tube sticking out each side. Bolt a small piece of angle to the WL 42 longeron with a hole in it. Put a rubber grommet in the hole. Once the whole thing is bolted up, you have the IP supported on each side by rubber grommets. The nice part is you can fold it down. Cubes |
| Author: | bfinney [ Wed Aug 16, 2017 12:49 pm ] |
Have a look at McMaster-Carr https://www.mcmaster.com/#vibration-damping-sandwich-mounts for isolation mounts, they have a selection of different styles. |
| Author: | blackopsspook [ Wed Aug 16, 2017 3:20 pm ] |
Thank you Bruce, that is precisely what I was hoping for. I can bolt the isolation mounts into the bulkhead and use AN bolts to secure the IP. That's perfect! L... |
