| Electric vs. manual trim http://thorp18.com/thorpforum/viewtopic.php?f=2&t=7981 |
| Author: | flyingfool [ Mon Aug 29, 2016 5:58 pm ] |
| Post subject: | Electric vs. manual trim |
If building new, is it really worth the trouble and expense to go with electric elevator trim? Do you save much or any space in the tunnel? I tend to like manual from as my experience with electric trim is that I either have too much or too little and find it hard to get the exact trim I want. With manual it just seems more infinite adjustable and I have more "feel" to adjust the trim. Which is lighter: manual or electric? I do plan on electric flaps to safe the tunnel and comfort space. Also I plan electric aileron trim because I don't know how to really make aileron trim manual that is effective. Maybe this year at KY Dam I will have to fly and feel how others have their electric elevator trim set up. If I'm going electric for the rest I may as well go all the way! By the way, my wife IS coming to KY Dam this year! Can hardly wait. |
| Author: | Ryan Allen [ Mon Aug 29, 2016 6:19 pm ] |
| Post subject: | Re: Electric vs. manual trim |
I just recently made the switch to electric pitch and roll trim. I like it better than the manual trim for both axes. |
| Author: | Hagle347 [ Mon Aug 29, 2016 8:06 pm ] |
In the past it was more difficult to find the exact motor to give the right proportion. If you use the Dayton geared motor for electric elevator trim, I think you'll be happy with the result. Another consideration might be how you intend to actuate the motor. 66WT has a panel mounted switch to move the motor. 218TH will have a coolie hat on the stick connected to relays then to the motor. I am happy with the result on WT - 218TH....I'll let you know next year. |
| Author: | jrevens [ Tue Aug 30, 2016 1:50 am ] |
Like you, I prefer the manual for most of the same reasons. There are pros & cons. The electric set up will be heavier I believe, and the extra weight is all in the tail. Not a big deal though on the Thorp. I didn't find the right angle drive I used, or the 1/4" drive tube to be any issue for me - it does take up a little room in the tunnel. |
| Author: | Rich Brazell [ Tue Aug 30, 2016 5:12 pm ] |
I believe you will find if the speed of the trim motor it too high it will be difficult to get that "sweet spot." You only need a small movement of the trim surface to get the desired results . Small movement , slow trim speed . A too high of an RPM you will overshoot the desired trim . I am always wrong at least 50% of the time ! RB BaBaLu |
| Author: | david read [ Tue Aug 30, 2016 9:49 pm ] |
Although I definitely see the advantages of the simplicity of the original design I have to say I like my setup. I moved the rudder cables outboard and put the flaps and pitch and roll trim all on the stick. That leaves nothing in the tunnel but the stabilator push pull tube. I made the rounded tunnel clear the tube by 1/4" at its highest point of travel and the sides giving the smallest possible tunnel. Thus a little wider seats and the tunnel sticks barely above the seats. It makes for a significant amount of extra room, worth the effort as long as you don't have to scrap any work you have already completed. My two cents. |
| Author: | Rich Brazell [ Tue Aug 30, 2016 10:16 pm ] |
David : That is the way to go ! If I had it to do over that would be 1st on my list no matter how much work it took . RB Shazam |
| Author: | jrevens [ Wed Aug 31, 2016 1:11 am ] |
I'm with you, Rich... I like what David did very much, and I'd definitely copy that if I was going to do it again (maybe in another life!). Right now I'm workin' on trying to make a nice Kitfox. |
