| Exhaust Pipe Fairings? http://thorp18.com/thorpforum/viewtopic.php?f=2&t=7273 |
| Author: | Ryan Allen [ Fri Apr 19, 2013 12:10 pm ] |
| Post subject: | Exhaust Pipe Fairings? |
Does CSA (or anyone else) sell exhaust pipe fairings? I am hoping to find something pre-made that would clean-up the area where my exhaust pipes exit the bottom cowl. |
| Author: | dickwolff [ Fri Apr 19, 2013 1:25 pm ] |
| Post subject: | Re: Exhaust Pipe Fairings? |
Newsletters and/or elsewhere on the this site (or the old one.) I remember some great photos where the fellow stuffed the flat stock through a slot in a piece of plywood and trimmed it later. Dick Penman may also have written an article on something similar back in the day. I vaquely remember a sketch. |
| Author: | Rich Brazell [ Fri Apr 19, 2013 3:23 pm ] |
CSA did have them (fiberglass) . Not sure about the status now ? Yes...someone did make aluminum fairings from a form block . Did not seen difficult . Can not remember who it was ? It was in a past NL . RB
| Author: | leewwalton [ Fri Apr 19, 2013 4:40 pm ] |
It's silly easy, I believe Dr. Stine has posted pics of the process. |
| Author: | Bill Williams [ Fri Apr 19, 2013 4:45 pm ] |
I wrapped a piece of .032 around a 2 1/2" PVC, bent ears with a brake and riveted them on the Aluminum cowl |
| Author: | Rich Brazell [ Fri Apr 19, 2013 6:46 pm ] |
Bill : Let's not make it a complicated process ! RB
| Author: | James Grahn [ Fri Apr 19, 2013 7:26 pm ] |
I just returned a set that Spanky bought back to Mike at CSA. Cubes |
| Author: | Rich Brazell [ Fri Apr 19, 2013 8:15 pm ] |
The fiberglass set I got from CSA fit just fine . I did not mount them on the surface of the cowl . I made a cut out and glassed them in flush . A lot of work for a guy that has little work working with the slime ! RB
| Author: | Ryan Allen [ Fri Apr 19, 2013 8:49 pm ] |
Bill and Lee make it seem so easy that I would be ashamed to admit whether I will make my own or buy a set from CSA.....but I really should help support CSA....thanks for all the info. |
| Author: | Rich Brazell [ Fri Apr 19, 2013 10:32 pm ] |
We need to support our Vendors! Back when I bought the fiberglass fairings , I think they were $8.00 each ? That was a while ago , but I consider that a bargain not having to make a mold , lay the glass , mix the goo and do layer upon layer . My time is worth more than that and by the time I buy the supplies the cost is not that much different . Some parts I could do with regard to the AC and others I left to the Vendors . RB
| Author: | dickwolff [ Sat Apr 20, 2013 5:47 am ] |
It was Dr. Stine. |
