It is currently Sat Oct 31, 2026 7:36 am
PostPosted: Sat Dec 13, 2025 7:06 pm
Guys
One of the worst jobs I do every annual is clean the exhaust/ lead residue from the bottom of my plane . To date I have tried most cleaners, gas and varsol. It usually takes 1-2 hours laying on a creeper using multiple rags. This year I tried Brake Cleaner sprayed on a rag and what a difference it made. I was done in 15 minutes and it removed all the crap from the bottom. Not sure what everyone else does but I thought I would pass the tip on.
Regards,
PostPosted: Sat Dec 13, 2025 7:11 pm
I have been using aviation grade simple green, but I will keep the brake cleaner in mind. cheaper than simple green after you have it shipped for sure.
pmandel
PostPosted: Sun Dec 14, 2025 12:28 pm
By "Brake Cleaner," do you mean CRC Brakleen? Stuff is awesome, please just be sure to use non-chlorinated. Otherwise, don't inhale ;--)
Philip Mandel
N118BC
S/N 957
Beaverton OR
PostPosted: Sun Dec 14, 2025 4:52 pm
Yes, that is the stuff.
PostPosted: Mon Dec 15, 2025 2:49 pm
I saw an article in Sport Aviation from a guy that used Goo Be Gone Citrus Spray Gel to remove exhaust stains from the bottom of his AC . Bought a bottle of the stuff and did a test spray on a small area . Let it sit for a few minutes and then wipe the area with a clean rag. IT WORKED ! As with any cleaning product test on a small area BEFORE you go full bore with the cleaning. A little of the stuff goes a long way . BADA BING , BADA BOOM !
O0 RB
NX115RX
2019
PostPosted: Tue Dec 16, 2025 8:33 pm
Jim, do you flush the airplane with water on the area you cleaned after using the brake cleaner?
PostPosted: Wed Dec 17, 2025 1:31 pm
I spray the brake cleaner on a rag so there is no real cloud or mist of the stuff. I wipe the lead and residue off. I have to flip the rag a few times because it becomes loaded with residue. Then I re-wipe with a soapy rag afterwards.
[ Time : 0.217s | 10 Queries | GZIP : On ]
