It is currently Tue Oct 13, 2026 11:13 pm
 Post subject: MA4SPA carb parts list
PostPosted: Sun Aug 14, 2016 3:42 pm
Anyone have an illustrated parts list/part number catalog/diagram for a MA4SPA carb . ??? Looking for the gasket P/N & lock washers for the pump inlet check valve assembly . That little housing on the bottom of the carb that has the raised "bubble ." :P I have looked and can not find a part number for the little bugger ! I have been to the Precision/Marvel site with no luck . :o I now return you to your regularly scheduled program .
PostPosted: Sun Aug 14, 2016 4:01 pm
See if this helps.......www.republicseabee.com/files/marvel schebler overhaul pdf
PostPosted: Sun Aug 14, 2016 4:48 pm
Thanks Bill : I went back and looked thru my personal email server and found an old carb manual with the part number . ??? I guess over the years you pack away all kinds of stuff that is right in front of your face !
[ Time : 0.093s | 11 Queries | GZIP : On ]
